Frige
I am making progress on my 96 gts rebuild. To recap it now has a 2000 717 engine and most of all the other parts to the 2000. I rebuilt the carb and I feel I did a decent job.
So I got the engine to start up and it sounds good. I am using a premix till the oil pump starts priming as the circuit is empty. I have not installed the jetpump yet as I want to run the egine for a bit and not burn up the seal. I started it by sqirting some permix into the carb and watched the filter fill up with fuel and then she ran on her own. I have a hose hooked to the water intake and there are no leaks. I was about ready to start adjusting the car when it died. I can get it to start by adding fuel to the carb but its not pulling any from the tank. I probably need to pull the carb but is there a way to test before I do that to figure out what is wrong?
