Here is a list of results you should get from testing your mpem on the 717cc rotax. Make sure you have all the wires completely disconnected or damage to your meter can occur.
METER + ...........................METER - ................................Value
RED........................................RED.... ....................................< 1 OHM
(ring terminal)......................(female terminal)
RED....................................RED/PURPLE.................................< 1 OHM
RED.......................................BLACK... ...................................> 20K OHM
(ring terminal)......................(ring terminal)
BLACK/RED..............................BLACK............ .........................> 10K OHM
........................................(ring terminal)
WHITE/GREY............................BLACK............. ....................... >100K OHM
TAN/BLACK..............................BLACK.......... ...........................>200K OHM
YELLOW/RED............................BLACK.............. .......................> 10K OHM
(female terminal)..................(ring terminal)
YELLOW/RED............................BLACK.............. .......................> 50K OHM
(male terminal).....................(ring terminal)
BLACK.....................................RED..... ...................................> 10K OHM
(ring terminal).......................(ring terminal)
I hope this helps.
Karl
