I have the sending unit loose, but do not seem to be able to remove it from the tank. It has four hoses and some wires connected to it. I can raise it up and it seems to be very close to coming out of the tank, but I have not found a way to get it out. Do I need to remove the 4 hoses, and or pull the tank out? How do I mark the hoses to be sure they are placed on the correct nipples when reinstalling them? Also the nipples are really close together and the factory used crimp on hose clamps. Is there room to use normal hose clamps?
By the way the reason I am wanting to get at the sending unit is fuel starvation at heavy throttle. The ski first started starving for fuel a few years ago, I checked all the filters, paid $600 to have the carbs rebuilt and it still lacked power. Then I found it ran fine as long as the selector valve was in the reserve position. It has run in the reserve position for several years but now it is starting to starve for fuel even in reserve. I have disassembled the selector valve and it is clean and flows well in both positions. Oh Yeah, and last year the fuel gage started reading full even when the tank was near empty. So the sending unit is suspected of causing fuel starvation and improper fuel level signals.
Any help will be appreciated.
