casims2000
Took the 98 Speedster out today and since I don't have a working fuel gauge, we opened the hatch to check the fuel level and noticed quite a bit of water. The level was up to the starters. Could not determine where the water was coming in from and didn't have that issue yesterday when we were on the lake.
The bilge pump works and it got me thinking about the mechanics of the pump. How does the water get pumped out into the lake? Seems the lake water would prevent the pump from emptying out the water unless the drain hole sits higher than the water, but that doesn's seem likely. I'm assuming water can't flow back into the bilge pump hose. Is it possible for the pump to be clogged? When I returned home I put water in the engine compartment with a hose to ensure the pump was working and it is. It's pumping out the water, but seems to take quite a bit of time. Wasn't sure if it's possible to plug it with oily water and debris that sits in the engine compartment.
Does anyone have any suggestions on where to look for leaks?
