Brew Master
Hey guys, with your help I was able to fix my rev limiter problem, now I took the boat out for the first time and and seemed to be a little sluggish out of the hole but to be expected with a single 800 motor. But the problem got worse as the day went on. Every time we stopped for a while it seemed to be taking on water, as in a inch or so by where your feet are. I opened up the engine compartment and there was water in there up to about the starter, maybe 3 or 4" . I noticed as the day went on it took longer and longer to get up on plane, to where it finally would not, im assuming because of all the extra water weight. The motor is turning 7k rpm. The bilge pump is working(at least I hear it) but not positive it is actually pumping.
So basically it ran great motor wise and at first would get up on plate relatively quick considering the motor size, but after every time we shut it off and stopped for a little while, then tried to go again it would take longer and longer to get up on plane to the point where it was full throttle for several minutes but would still not plane out. Any help is greatly appreciated. thanks Mike
