Yup, down on the Chesapeake bay last weekend, boat loaded full of peeps, slow idle away from the sand bar then mash the throttles on my 200 speedster-she lifts outta the water quickly then the dreaded SHUTTER!!!!!! right prop is either clogged or stuck...
I drift further out, drop the gate, try floating in reverse after a few revs....nothing clears it
limp back to dock, up on trailer, drop the gate down and up inside is a pair of Jockey Flannel Briefs!!! WTF??
it blocked all flow to the prop by sitting over the impeller blades and acted like the clutch was slipping as it shuttered..cleared it out back in the water 2 hrs after suck in and running.
I really wish these boats weren't so vulnerable to crap like this! Yamaha has a top opening cleanout port you can access from the deck which would have fixed this in 5 minutes.
