tachometer
tony0713
my 03 challenger 1800 needs a new tachometer. i found one on ebay right with from a 2000 challenger. I've searched a couple parts sites and found different parts numbers. so I can't match any. will this one work?
It's hard to say since you aren't showing us the part.
Also... a "2000 Challenger" isn't a good description, since there is a model YEAR 2000, and a model 2000.
Finally... what engine do you have? (add your boat to your signature line)
Where in PA re you?
A quick search for that tach number 204470807 has been replaced with 204470962 so both should work
Challenger 1800, 240 ER, 2004
Challenger 1800, 5774/5775, 2003;
Challenger 2000 240 EFI/250 Optimax, 2004
Challenger 2000, 5776/5777, 2003;
Challenger X 240 EFI/250 Optimax, 2004
Challenger X, 5778/5779, 2003;
Islandia, 250 OPTI, 240 EFI, 2003
Islandia, 250 OPTI, 240 EFI, 2004;
Speedster 1600, 240 ER, 2004
Speedster, 5772, 2003;
Eddie
Must be the same reference if you do not work ...
Check with the same plug.
the boat is in storage so I can't look at the plug right now.
Where in PA re you?
the year 2000 challenger.
I have the 240 I believe.
I live just northwest of Philly but boat/have a house on the jersey coast.
Eddie
the part number for the 03 challenger and speedster are different but they look the same. anyone know if they are interchangeable?
Depending where you look you will find that they list the number and what number it was replaced by. 204470962 is the current number and the tach will work on all the models that are listed.
