Brightondale
I've had a non working speedometer for the last 13 years on my 2002 Sportster LT and a non working starboard tachometer for the past 2 years until I came across this thread:
Scroll down a ways to where you see the post from "donnyd"
http://www.seadooforum.com/showthread.php?14299-Tachometer-on-98-Sportster-inop
I've reposted the pics from donnyd here
Speedometer: 204470322
Tachometer: 204470321
Both gauges have the same workings.
I wanted to chime in on that thread but it was closed, hence the new post. The fix for both the speedometer and tachometer was to cut open the back between the plastic threads and very back. I used a dremel grinding wheel. This back circuit board is about even with where the last plastic thread on the outside so there's enough of a gap to cut safely.
As shown in the pic, pull the assembly out a bit. Reheat the three (3) largest solder spots on the exposed circuit board, let cool and close it up. Easy-peezy. Apparently these electrical connections will vibrate loose and lose contact with whatever is beneath them. I didn't bother to do anything to seal the cut like donnyd did because the back already had open holes and gaps, ie it wasn't sealed to begin with.
I was shocked to see both gauges working again. Especially the speedo after 13 years. It's just a shame how many of these gauges must have been thrown out or just dealt with as non working like I did. These speedos aren't even usually available from dealers anymore. The tachs run $360ish new. Even used, either of these guages fetch $150ish with faded needles and scratches.
Hopefully more people can learn of this incredibly easy fix and not spend a dime.
