his is the snow and ski specs Material Code 621612001
Gravity, ASTM D 4052, °API 32.5
Density, lb/gal at 60°F 7.19
Flash Point, PMCC, ASTM D 93, °F (°C) 158 (70)
COC, ASTM D 92, °F (°C) 194 (90)
Viscosity, ASTM D 445, cSt at 40°C 56
cSt at 100°C 8.5
ASTM D 2161, SUS at 100°F 288
SUS at 210°F 54.9
Viscosity Index, ASTM D 2270 126
Pour Point, ASTM D 97, °F (°C) -44 (-42)
Appearance, Color Purple
Sulfated Ash, ASTM D 874, % 0.10
Total Base Number, ASTM D 2896, mg KOH/g 1.1
this is the BRP XP-S Synthetic Oil Gallon 293600046
Boiling Point: ND Specific Gravity (Water=1): 0.93
Vapor Pressure (mm.Hg. @ 25 ÿC): ND Vapor Density (Air=1): > 1
Percent Volatiles: 10-20 % Evaporation Rate(BuAc=1): < 1
Solubility in Water: Negligible Freezing Point: -65ÿF (-54ÿC)
H-Value: NA Viscosity @ 100ÿC, cSt.: 7.4 typ.
Odor Threshold: ND Coefficient of Water/Oil Distribution: ND
Appearance, Odor & Physical State: Dark liquid; mild petroleum odor
SECTION VII: FIRE AND EXPLOSION DATA
FLAMMABILITY Yes [X] No [ ] NFPA Class IIIA material - Combustible liquid
Flash Point (PMCC): 190ÿF (88ÿC) min.
Fire Point (PMCC): 190ÿF (88ÿC) min.
Autoignition Temperature: ND
Flammability limits in Air, % Vol.: Upper - 6.0 Lower - 1.0
do you think I could mix these safely.
