Hi All, No stranger to wrenches but this is my first dual carb machine. I've pretty much done everything by reading this site and the manual, you guys are pros and I appreciate all the info you freely post.
I Bought a 97 GSX (787) on the cheap, was running lean (runaway). So I've gone through and rebuilt the carbs, replaced fuel lines, etc... What I'm struggling with here is syncing of the throttle plates. I've had the carbs on and off a couple times since rebuilding and have had the doo running, but have been waiting for new base gaskets. Now that they're in, I want to do this the last time... Properly.
If you follow the manual, first step is to turn out the idle screw and make sure both plates are both fully closed. Manual shows this with the linkage bar disconnected. Then connect the linkage bar and make sure they're still closed.
Next in the manual is throttle cable adjustment which specifies to hold the throttle wide open. In that position the spacing between the throttle stopper is .5mm (1/64") away from the carb body.
But if you adjust according to this, your throttle plates will no longer fully close, at least mine don't seem to. Additionally, there isn't slack in the cable. The first time i put them back in and adjusted like this it idled high until i backed off the throttle cable tension.
So how critical is that .5mm WOT spacing?
Should i just sync the carbs closed and not worry about it?
how much slack (by feel or sight) is appropriate in the throttle cable?
Before turning in idle screw should the throttle plates be fully closed?
Thanks
Thanks
