Switching back to stock exhaust from Factory Pipe
Matthew Sean
Are the any electronics to consider when removing a factory pipe? I noticed the rev control solenoid wire was hooked-up in the electronics box. Is the a special computer to reinstall for a switch from FP to stock exhaust system?
No... the stock pipes only have water connections from the water box to the pipe. Depending on which engine you have. The 95 did not use the DESS system so the only parts to your electronic module are the rev limiter and ignition module. Any electronics that were installed with the FP, should be able to be removed. Without seeing how (or what type system) it is set in play, hard to determine exactly what you have. But, the stock system has nothing but water nipples.
What engine is this coming off of
Sent from my C771 using Tapatalk 2
