VERDUGO135
Ok. As far as rpm goes port engine starts off running about 500 higher than starboard when throttle levers are even. At about 4500-6000 port engine surges up and down. After 6000rpm they both run smooth and starboard goes about 300rpm higher. They even out close to max rpm which is about 7600rpm for both engines on flat water. Speedo shows 55mph max.
So my question is what should I look for? Going to change spark plugs and add a fuel injector cleaner. I checked to make sure chargers don't spin by hand but will be removing them for closer inspection. Boat is a 2008. Does this mean washers were metal from factory? Thanks in advance.
