Longtime lurker, but first post. And of course with an issue.
I have a 2010 180 Challenger, 255hp. While running down the lake I experienced a sudden drop in RPM's, down to 6068. Felt just like pulling the throttle back. Now that's all it'll do. At WOT all I get is 6K rpm's. Boat runs fine other wise. Idles well, throttle response is good, just won't get to the @7800. There are no warning lights, error codes etc. displayed. IT has 67hrs total on it. During my search I ran across some info abaout the IAT (intake air temp sensor). Some stuff about issues, a recall, etc. Mine has the "green" sensor, open air type thermistor. I ohm'd it at about 75 degrees F and read 1500 ohms. Is this in range? With a little warm air the ohms decreased as expected. Could this sensor be bad with these readings? Could/will this cause the issue I'm experiencing? Any help or direction would be greatly appreciated.
