sucked up a plastic bag
alex1
noticed slight abnormal noise from the impeller while flushing the cooling system... looking through the nozzel ... i found a plastic bag covering the impeller ... how can i remove it?
pull off the grate and see if you can get it out that way...
I bet you would be able to get it out...
it's difficult to reach from the water intak gate ... most of it is covering the impeller and in the impeller housing ... between the impeller and stationary vanes .... is it possible to clear it through reomoving the venturi?
pick out what you can and go for a ride. once you tear it up with the hanger, the pump will blow it out.
