jimatsamrayburn
My 1999 Challenger did...anyway. It was caught up in the impeller when I got it back on the trailer. It is reving and not really moving forward.
Sounds like from all the replies that I need to replace the wear ring so I got a removal tool and three wear rings coming on Friday...plan to replace all and have a spare.
The Shaft Protector got a 1/2 inch piece that broke free on the bottom end. Not sure if I really need to replace this as well.
There are some very small burs on the impeller.
Any thoughts on replacing these parts? Any place to get cheap impellers?
Also....I had the boat running around 50mph and I was messing with the reverse cable and afterward the boat was only running 40mph. I did replace the plugs (even tried the old ones back so that is not the issue).
I saw posts about adjusting the cables and wear rings (again).
Could taking the throttle/reverse controls out and putting them back in slip the cable adjustment enough to slow the boat down 10mph?
I'm working on the boat this weekend so any input will be greatly apprecited...loved the boat when it could jump out of the hole.
