yes it is styrofoam, but on the outer sides that faces the motors both have like a heat resistant foam wich soaks up water.
yep sure does, thank you. I take it you looked at your sink and yours in the same way? I think what I might do is see if I can actually just mount the styrofoam on the sidewall so its not just sitting on the bottom of the hull. It really doesnt hurt anything the way it is, I just dont like the idea of that egg crate foam beeing wet all the time. lol.
See???
Just fyi... the oil gauge has been removed from the system... Lines are cut and sealed off. Just in case someone was wondering.. No clue why. I will probably reconnect them at some point this winter while I'm working on it.
See???
hmm, i can tell that you are right handed, took the picture in your parent's basement and your fuel tank is half empty.
