Frank_Hassa
I bought the recommended JIS #2 screwdriver, but I got it from eBay not Amazon as recommended by the member in a previous thread. So full disclosure, it's possible I got a fake JIS screwdriver, because the head looks EXACTLY like a #2 Phillips. I can post a picture if anyone wants to see it. Looks exactly like the one from Amazon, mostly red and black, same printed words on it, says it's JIS, etc... but it doesn't fit the Mikuni Carb screws any better than a DeWalt #2 Phillips screw gun bit. Flops around in there a little bit.
The first screw I tried stripped out completely. So I went with a cordless screwgun with a brand-new #2 phillips bit and set the torque real low and slowly worked my way up. It started turning the screw at about "18" (out of 20) and the ratched/impact effect of the screw gun seemed to give some time for the screw bit to slip back and "reset" before the next hit, which is why I only partially stripped 2 more screws out of both carbs (which I think is about 16 screws total).
Learned the difference between "Mag" and "PTO" and got clear on the accelerator pump and how it's 4 screws are necessarily longer than the others. Not certain but I think there are 3 lengths of screws.
I have one totally stripped screw and two partially stripped screws that could probably be used again, but now I hate stainless steel screws because I can see how much weaker the metal is than standard steel. The one that is fully-stripped peeled some of the aluminum threads from the body of the carb when it came out. Not much, but some.
I've read about people going with Allen Screws, and I'd like to do that. Looking for a compelling reason not to. Also I'm having trouble finding a replacement screw for the one that is stripped, and the prices are crazy when ordering them as "Seadoo Parts". I know they'd be much cheaper if I simply ordered "M6 x 12 mm stainless steel screw", but that's the problem, I don't know the specifications. Looked all over the parts manual, etc... and I can't find any reference that gives an, uh... "absolute" description of the specs of these screws (thread, length, etc...).
Does such a reference exist? How can I order $3.00 worth of screws and avoid paying $30.00 for them? Is converting to Allen screws a good idea or bad?
Also: Was that loc-tite I was fighting with? There was a hard white substance in the threads. I thought it might have been corrosion since I expect loc-tite to be red or blue, but industrial loc-tite could be totally different. When I reassemble them, should I use loc-tite again? What strength? I'm more inclined to use grease, not loc-tite. How likely is it that these screws will vibrate-out if I don't use loc-tite?
