I recently purchased a 150 Speedster with the Supercharged 215 motor .... I installed a solar powered battery 'trickle' charger along with a tracking device recently and during the install I felt resistance pulling the wires through the hull....nothing dramatic but a slight tug that made me think i might have got tangled up with something in the right side of the hull. The wires are totally separate from all existing wiring and run direct to the battery by passing the isolator. Maximum charge is around 2 amps at most just to keep the battery 'topped up'
I didn't attempt to start the boat until yesterday.
When I attempted to fire it up, it gave the impression of a flat battery .... just a dull click from the starter... nothing else. Whether or not the DESS made any of its normal noises I cannot remember ......
I checked the battery with a voltmeter and it read 12.8 V, checked the fuses in the instrument cluster and all good with same voltage of 12.8 V across all of them. Checked engine compartment fuses and strangely they read around 7 volts only ......
I checked voltage from the battery to the starter solenoid and was amazed to see that the feed side to the solenoid read 12.8 V while the starter motor side read 7.0 volts without the solenoid being activated so it is a bit weird for sure.
Followed on to the neutral safety switch..... found that it had an open circuit so assumed I must have caught it while pulling wires through.. Decided to by pass the switch to see if it would start but still nothing.
This morning contacted a couple of Sea Doo dealers here in Perth, Australia but they seemed reluctant to look at it due to its age. One of them even said he didn't have diagnostics for the older boats .... mmmmm
Anyone have any ideas on what may be the issue ...... is there a reasonably priced diagnostic tool I can get that would help
Hopefully someone might have an idea as to where to look ..... thanks in advance
