ChicagoFunSize
Hello group, this is my first post or help. I just bought a used 2006 Sportster 215 and I took it out for the first time. After shifting Forward, Neutral, and Reverse a few times, I was comfortable exiting the harbor to enter Lake Michigan. As I was approaching the light, I tried to shift to Neutral to wait for the light the shift lever was stuck 1/4 of the way back to Neutral so I stopped the engine and stayed calm. To shorten the story, 5 minutes later, I went to the back of the boat and manually pull the reverse bucket to neutral. Saved the day and trip. Had to do that a few more times before the trip ends.
When at home, I did the inspection and found the stop pawl screws are rubbing the stop mechanism, note some wear in the third photo, and created some friction coming from Forward back to Neutral. I could have yanked the shift gear really really hard and possibly get it to N but I certainly didn't want to force anything, especially when I don't know enough about how things work.
Here I see a few options:
1. Loosen the reverse bucket left bolt and tighten the right bolt enough to clear the screws.
2. Grind own the screw pockets by a few millimeters
3. Grind down the screw head - which is NOT an option I want to do
4. Grind down the bracket where the wears are (see the one with 3 arrows) but that will thin down the pin holder. Also don't want to pursue.
I'd already taken the stop pawl out and shifted back and forth to make sure the shifter are working smoothly.
Anyone has any experience with this. I would like some advice. Thanks again!!!
