silverstrk65
Trying to dial this thing in. 96xp.
ADA head(175psi)
Factory spec 2 pipe with ecwi
Tdr waterbox
Novi maxiflow rotary cover
Full spectrum 46mm carbs
Remote fuel pump, return jetted to 70
Prok arrestors
Msd enchancer
X/O impeller
Runs great no hesitations but revs 7040 max on my koso gauge. I think I have a issue with the microtouch controller for the water injection. When I plug the fob in I hear the solenoid click right away. I would think it’s not supposed to come on til alittle later. But when making a wide open run at 7k and idle back to shore the stinger is reading 400 degrees according to my laser temp gun. Way too hot IMO. I have a 135 jet in the head pipe after the solenoid. 90 in the mid and a 140 in the waterbox. While on the water I pulled the jet out of the mid pipe to try. Didn’t lose any rpm and the pipe now gets around 200. I even disconnected the solenoid for a short run and seen no difference. Rpm or temp. Reading previous post on this and seems like everyone is running similar setups. Gonna bunt for a new controller but wanted to see what some other opinions were.
ADA head(175psi)
Tdr waterbox
Prok arrestors
Msd enchancer
X/O impeller
