I now have 30 hours on my 230 Challenger. I put 15 hours on it last year then when it was winterized they performed the first service. So far in the last two weekends I have racked up the other 15 hours cruising around the lake and learning how to handle the boat going very slow around the docks. I have had it to the dealer two times for the steering and they have not been able to correct it. The issue is that in order to make the boat go straight you need the wheel 90 degrees to the port side. They have adjusted the nozzles but it has not helped. This has been an issue since I bought the boat last August. What are your thoughts on possible causes? I am wondering if the port side pump is "stronger" and causing the boat to want to turn to the starboard when the nozzles are both pointing straight??? Also to maybe support my theory I made my first full throttle run the other evening and the starboard motor RPM's were fluctuation 2-300 while the port motor RPM's remained steady and the sync light was on so they should have stayed at the same RPM. The top speed I could get was 59MPH with full tank of fuel and about 500 pounds of people, dog, and gear. Does that seem about right? I was expecting more from 510Hp. I guess I will have to try it with less fuel and just me. Fun boat so far and tunrs a lot of heads.
Thanks
Brian
Thanks
Brian
