eekachouh
Hello all
I am not sure if this is a problem or not. I noticed a little play on the metal bracket behind the steering wheel. It is the bracket where the steering cable is attached. The metal bracket touches two rubber stoppers. Is it possible for this bracket to get loose and I will need to remove the steering wheel to tightened it up? If this is the case, is it an easy task to do? I took the steering wheel out, but I am afraid to remove the single nut behind it. Any help would be appreciated! By the way, what is the formal name for this bracket?
