WhiteZombie
As you can see in the pic, the brace for the assemblies is crocked. I have installed it tightened and untightened on the brace mounting screws and get the same result. There isn't much clearance in the mounting holes to the boat and looking at the bottoms of the assembly to the hull it doesn't look off, so I don't know how to adjust this.
Also, I don't know if you can tell the casting on these jets is different, but the one on the left is a bit heavier made, and by so being it is 1/4" smaller diameter than the jet outlet on the right. Can someone check to see if their is like this. I would think they should be the same diameter. I know 1/4" doesn't sound like much, but that is quite a bit of difference area wise chocked down on the left side. I don't know if this is by design or if this was changed out with the wrong outlet.
Also, I need to adjust the right side out a turn or two on the adjustment. I was just reading a post where someone said to align them flush with a straight edge and someone said to have them slightly pointed inward to each other. Which is the right way. I don't recall seeing this in the service manual. Thanks
