seadoo_mike
Thought I would do some maintenance after winterizing the boat. It is a 2009 challenger with only 55 hours on it, but I wanted to replace the wear ring even though it is in ok shape, and also pull the pump cone off and check it out. I pulled off the pump cone and found not much grease in there at all (picture below). Is it best to clean out the grease and go with synthetic oil? not sure why BRP went with the grease instead, but it doesn't look like it is doing anything, I can see the actual ball bearings. If I should use oil is mobil 1 ok to use and how much oil should I put in there.
