fowlerrudi
Hello folks, this is my first post! I bought a 2001 utopia 185 with 200 Opti this week, for a song. However, it was cheap because the impeller shaft was seized. Turns out it is seized in the stator. I opened up the fill and check plugs on the stator and sure enough, dry as a popcorn fart, just some green corrosion in there. I put some “ultimate penetrant” in there and it’s soaking now. The engine will not spin this shaft in the stator at all. When I hit the starter it tries to spin the entire stator housing. Anyway, I can’t get this stator off, I’ve read all the forums of guys having the same problems, but I don’t think anyone actually had the engine not spin over. It was in salt a few times, so I imagine it has welded itself to the bushing in there. The previous owner said it failed while in use, he thought the engine seized. With no oil in there it most likely got hot. I built a bracket with angle iron and been trying to smash it backward with a slide hammer, while being hooked to my brothers cummins, and almost pulling the boat off the trailer.... we are thinking of making a puller that runs a bolt through the center plug into the end of the shaft as to push on the shaft. What has worked for you? Thanks! Standby for video!
