S shaneseader Member May 30, 2021 #1 Is it normal or ok for a little water to leak between the two housings?
T Tim75 Well-Known Member May 30, 2021 #2 shaneseader said: Is it normal or ok for a little water to leak between the two housings? Click to expand... How are you judging your leak? Two o-rings should have been replaced while it was apart.
S shaneseader Member May 30, 2021 #3 It’s not leaking on side with o rings. On the back side of it. Where it’s just metal to metal
