Hi To All - Got a 2002 GTX DI from a friend, who trailered it behind the barn for last 7 years. New to PWC. Have Parts Catalog but not Shop Manual. To start the revival, drained all fluid and cleaned gas tank twice. Blew out all lines. New spark plugs. New battery. It tries to start - almost - so decided to go further. Ordered new fuel pump, new injectors and rebuild kit for air compressor. Jet pump looks good and can't decide whether to rebuild; buy new one; or just try to see if old one will work.
Hoping to get some advice and guidance and if our approach needs to be added to. For example:
*in order to change the air compressor, a video we watched shows to pull the harmonic balancer. Is this correct? Are there cautions regarding reinstall of balancer?
*is it advisable to rebuild a jet pump? Are there tricks to it? Where is best place to get the correct rebuild kit?
*If going to try our luck with the old jet pump, what is minimum required maintenance and repairs needed?
*Seen on other Post that some of these components - fuel pump maybe? - need to pressure tested. Anything else need to be tested? How to test please?
THanks for your time and help.
Steve
Steve
