atlantis6
Hello
Earlier i posted a thread about my solenoid because i touhgt it was the problem.
Now we tested it and it seems that it is still good, put 12 v to it and it clicked en measured 0 ohm.
the next test i did was the lanyard on pos 1 tested the red wire on the solenoid with ignition key on result 12 V.
I assume this means that the ignition key works.
There is also a thin yellow-red wire on the solenoid there is no 12v on it or is there only 12 v when the ignition key is turned over.
What i did next is red wire from battery connecting with the yellow-red wire on solenois and solenoid clicked but starter did not turn.
I measured the voltage on the starter when big red wire en yellow-red wire where connected (12v) got about 4,5 V on starter i can think that this is not normal.
Anyone any idea what is broken
