starting problem
iridea96xp
i have a 96xp and after riding a while and stopping it doesnt want to start back. i have a k&n breather and had popoff adj but maybe to much.
i was told it could be constantly dripping fuel causing it to flood when engine
is off please help
I have some info on POP Off Pressure for you to absorb.
Pop-off is the measurement of the point where atmospheric pressure overcomes the fuel draw vacuum of the carb. The entire regulator chamber is nothing more than a big check valve. It is the step between the fuel pump, which is providing more pressure than the carb needs to deliver, and the jets, which meter a fixed amount, within a certain pressure range. The regulator chamber is in place to maintain that pressure range.
The whole regulator chamber gets filled with fuel. The fuel is coming from the pump, sits under the diaphragm, and is flowing through the jets. If it was just an open flow, with no needle and seat, the jets would be supplied with too much pressure from the pump. As the fuel is sucked out the jets, the fuel supply in there is drawn out, and the diaphragm goes down with it. As it gets to it's low point, it contacts the lever arm, and lifts the needle from the seat. That allows more fuel into the chamber, pushing the diaphragm back up, re-seating the needle and shutting off the flow from the pumps, so the jets aren't over-pressured. This happens many, many times every minute as fuel is consumed.
If the pop-off point is set too low, there isn't enough resistance on the needle to stop the fuel pump flow, and the jets are over-pressurized, giving you a rich condition you will never tune out. The same goes for leaking needles.
If the pop-off is too high, there isn't enough fuel pressure to overcome the vacuum and spring pressure, and you will have hard starts, as the engine is not spinning fast enough o produce enough pulse, to make the pump supply enough pressure to flow the fuel into the regulator chamber.
It is adjusted by changing the size of the N&S, and the spring tension. There are 4 general strengths of springs - the less the spring is rated the lower the pop-off pressure will need to be to unseat the needle. For example, a 65 gram spring may give you a pressure of 15 psi, where a 115 gram spring may give you 50 (not actual numbers).
You test the pressure with a pop-off pressure guage. With the regulator chamber open, wet the N&S with WD-40 or gas. With the pump body removed, attach the guage to the fuel inlet fitting on the body. Pump the guage until it 'pops' noting the pressure guage. Repeat this 3 times to get a nominal reading. Installing a heavier spring will raise the pressure. To adjust in small increments lower, cut coils 1/2 coil maximum and re-test.
NOTE: You cannot accurately test with the pump body and fuel filter still attached to the carb - you MUST disassemble it and test directly into the fuel inlet orifice, where the fuel filter sets. Otherwise you are testing through the pump check valves, throwing your readings off, too high. If you have an external fuel pump, this does not apply.
Go and re-do it I think this info will help. Let me know if you still having a problem.
Karl
