After sitting for a while, I just got some fresh fuel in the tank, lines, VST and replaced/pre-filled the filter/separator. I even filled the VST with fresh fuel, let it sit overnight and drained it (the fresh fuel removed varnish deposits and the new fuel I poured in it smelled old).
When I turn the key on, I can hear and feel the pump pulsating (the pump that's connected to the fuel line from the tank). I cracked open the plug on the bottom of the VST and fresh fuel came out so it seems the primer pump is working.
I suppose I can squirt some pre-mix in the spark plug holes to see it it runs for a second, correct? Any other ideas of what to check?
Thanks for any help,
James
EDIT:
I just verified that the engine runs for a few seconds with some pre-mix shot in the spark plug holes. Since I know the pulse pump is working and filling the VST, should I look into VST issues? Like the pump not working, clogged screen, stuck needle etc.?
James
EDIT:
