I have a fully rebuilt 95 XP. When I say rebuilt I mean every single component inside the ski was replaced last year.
The only thing that was not replaced was the ebox itself, however all the major components (mpem, solenoid, rectifier) were replaced inside the box, except the actual wires (excluding the main wires going to the solenoid) remain as they were when I got the ski.
In the last 2 months I have been able to put around 12 hours on the ski. However twice now the starter has just given out on me. The first time I was unsure what the problem was and posted in this post for advice solenoid clicking .after trouble shooting this issue for about a week I determined that the starter had just given out on me and replaced it with a used OEM starter.
Both scenarios are more or less the same. I had the ski running perfectly fine for around 5 to 6 hours spaning over several trips to the lake. Then all the sudden the ski will not start anymore. When I push the start button it just gives me a click and nothing else.
What is wrong that is causing my ski to tear up starters so quick? I cannot for the life of me understand what I could have done wrong to cause this issue.
How could the ski be seemingly working fine and then the starter just gives up?
The only major difference between the first time and the second time are as follows.
-drove ski from CO to TN for vacation
-due to elevation change and wanting to be on the safe side I turned the low speeds to run very rich and then tuned them back down.
-during this process the ski was flooding frequently on me
-due to frequent flooding the ski was dying and having to be cranked on quite a bit
-however I did get the tune to a place I felt comfortable that it was at a good mixture and then the ski was rode for another hour or so before this issue came up again.
*because the fact this issue happened excluding such things on the first I'm unsure of how important they actually are*
I want to thank you guys in advance for any and all advice. I'm very close to just giving up on it and selling it. I fancy myself a pretty decent mechanic and I try to read and soak up as much info from all sources (this and other forums, manuals, seadoosouce, etc). So it's really starting to kick me in the pride that I can't just have a ski that runs for a reasonable period of time.
