I have a 2007 rxp. Put it in the water this week and have been having starting problems. Its got all the classic symptoms of a bad starter relay (clicking when Press the start button, cranks right up when I jump the poles with a screw driver). The problem is I have replaced the starter relay 3 times this week and it still won’t crank with the start button. When I replaced it the first time and it didn't fix it I took the relay back to where I bought it from thinking they sold me a bad relay. I was so convinced it was the starter relay causing the problem that when the second one didn't fix it I started to think maybe this store just had a bad batch of relays so I actually went to a different store across town and bought another one. Well jokes on me...it’s clearly not the starter relay because the third one didn't fix the problem either. I’ve checked the volts on the battery, the volts on the cables running to the starter relay. I even unplugged the cable running from the start button to the starter relay and checked the volts on it when i press the start button. All had 12+ volts coming off of them. Bottom line is I'm stumped and don't know which direction to to go in next. Any help would be greatly appreciated. Thanks!
