I have a Seadoo 96 Spx with a starter problem. The starter will turn over the engine maybe one or two times then stop. Battery and cables check good. Local Seadoo mechanic said if the engine turns over freely with the plugs removed that the starter is bad. Tried it with the plugs removed and it turned over fine, so I replaced the starter with one from eBay (not OEM). Well, it's still doing the same thing (starter engages, but it barely turns the engine over).
So, now I'm thinking it's probably the starter selenoid. The Seadoo troubleshooting section says if the starter does not turn that it may be a defective selenoid (lanyard or starter switch), but if the starter engages to check various parts of the starter motor.
Should I try replacing the selenoid?
BTW, My Seadoo manual says the selenoid part number is 278000513. I've been told you can also use part numbers 278001376 and 278001802. Anybody know if this correct?
Thanks!!
Thanks!!
