gerrychuck
Ran into issues starting my 2002 Challenger 2000 this weekend. Started fine at the boat launch and 20 minutes later when I took it back out for another test run, but the next day it wouldn't; starter did not seem to engage. Put a booster pack battery on and it started and ran, but trying half an hour it was back to spinning but not engaging. Tried the booster again without any luck. Took the battery out and charged it from my truck, reinstalled, no luck. Battery will run the inverter to power my airdock pump just fine, which it won't do if the battery is not putting out proper voltage (believe me!), so I am pretty confident the battery itself is okay. Took the cover off the top of the powerhead to expose the starter gear; starter spins but the gear does not pop up to engage the ring gear. My mechanic son was helping me troubleshoot; gently prying on the starter gear it would come up part way but stop hard well short of the ring gear. Not sure if this is normal. Unfortunately, we did not have any electrical testing equipment with us to help with diagnosis.
I am assuming the problem is the solenoid, but would appreciate any help. Question: where is the solenoid located? Is it remote from the starter?
Thanks in advance for any assistance.
