MexicoJoe
Hello all. I have spent many nights reading through forum posts diagnosing issues with my 97 GTX over the last two years so I can't thank the forum enough. This week I've come across this unusual problem with my ski that has me completely stumped. Took my ski down to Mexico to go fishing in the Sea of Cortez. Ski ran great per usual for the 3 days we were there. Got home late so the next day is when I cleaned the ski. Went to start the ski before I hooked up the hose to flush it out and nothing. Put my multimeter on the battery and it has 5v. The battery was 1 year and 4 months old so I figured that was great that I got more than a year out of the battery considering I hear that these AGM batteries for skis don't tend to last more than a year. No worries. I bought a new AGM and go to put it in. Hook up positive first as you are supposed to. Now here's the problem. As soon as I touch the ground, huge spark and starter starts cranking away! Mind you, the key wasn't even on the DESS post. I know how to test solenoid so I get out the multimeter and sure enough I have 12v on the second post that leads to the starter. I then go inside and read as many forum threads as I can. If I disconnect the 12v signal wire plug I do NOT have 12v on the starter side of the solenoid. I made sure to remove the solenoid and test for continuity between the two posts and I do NOT have continuity. I was 100% certain that my solenoid is good however, for craps and giggles I bought a new one anyways. The new one has no continuity either so it is good. I put it in today and low and behold SAME ISSUE.
If I press the IGNITION GROUND to the negative post on the battery I can hear the solenoid click. So basically the 12v signal wire or MPEM is CLOSING the circuit at the solenoid. Again, all of this is without the key on the post.
Another thread I came across doing a Google search basically lists the same exact problem. The poster says that it ended up being the MPEM. I have traced all wires from the rear electrical box, red signal wire with yellow tracer to the MPEM. Nothing looks out of the ordinary. Ski is in excellent shape for the year. Opened up the MPEM and it is so clean and new looking you could eat breakfast off of it. I don't see anything corroded or salt or anything. The box has the gasket and is water tight and again no signs of anything. I can't imagine the MPEM got fried. I wouldn't understand how.
Just trying to figure out if it truly is the MPEM before I pony up the dough for a new one.
Anyone have any thoughts?
Thanks!
Thanks!
