Jumping solenoid!
Follow your red (positive) wire from the battery into the electrical box. Remove this cover. In there, you'll see the solenoid for the starter. Take a large gage wire, or two screw drivers and cross the two points where the wire breaks between the controller (solenoid) and you should get the starter to roll over. If it only clicks, the starter is bad..............:cheers:
