Start engine with stator, wear ring, and impeller removed?
welbytrise
Title says it all. Is it ok to start the engine with the stator, wear ring, and impeller removed with a water hose hooked up and running?
Ummmmmmm.........................
I don't think I would do it. Without the support of the stator... the gears may not mesh correctly... and... the impeller shaft could sling around, and bend.
