rgbradbury
Hey guys,
I got this boat 4 weeks ago and I already have my first big issue, woohoo.
I was out tubing today and after about an hour of playing and a 30 minute rest, I fired the boat up to take it in. When I was pulling away, the right engine would only go to about 3500 rpm then cavitate heavily and the revs would then drop. I thought that I had sucked something up into the system. I got it to the dock using the other engine and had a good look around to see if I could locate the problem. I couldn't see anything in the pump, but I did see that the impeller boot had split and was coming out.
Got the boat home and took the pump off.
That is what I found.
Could this be causing the issue I was having? I thought that these things just kept water out of the splines. There didn't appear to be any damage to the splines on either the impeller or the driveshaft. Any ideas would be helpful.
