1997 Seadoo Challenger 1800Starboard Motor Throttle seems to be stuck, engine revving high in Idle.....up to 3,000 RPM. Is there anything I can do to reduce this or check the Throttle cable if its stuck. Nothing is binding up in the throttle when using the throttle to drive the boat, the idle is extremely high vs the Port Motor (Normal 1200 to 1500 at idle). Ideal or solutions????
