Starboard engine p0353 p0351 08 speedster 200
ckgixxer
Under 3k rpm I am getting a p0353 and p0351. Shut off restart will go and run awesome, then at idle for more the 1 minute code comes back up. Switch coils same code check coil connector and they are in good shape no damage or corrosion. Even pulled on them pretty good.
I have seen where it was the rear oil pressure switch sometimes throws that code?
And is ok to run on port engine with starboard in limp mode running at idle to keep exhaust water out? Or shut it off and pinch lines?
Thanks for the advice
Ok so replaced all coils spark plug, coil connectors all look in really good shape. Cleared all codes took it out today run fine about 35 minutes stumbled to could feel it like I sucked something up (assuming coil was misfiring) shut it off restarted ran fine, ran it for about 15 more minutes then it short beeped once and shut off? Removed lanyard wouldn't start till I removed it. Fired right back up ran good about another 20 then shut off again. Never stumbled again only did that once. Plug candoo in and no codes what so ever. Anyone have experienced anything like this?
