dabernathy8181
I have a 1996 GTX with the 787. The ski was parked for about 6 years before I got ahold of it. I pulled the tank l, replaced the fuel lines, put a new filter between the tank and carb. Pulled the carbs and rebuilt with genuine mikuni parts(I learned my lesson with vertex rebuild kit and Mikuni is all that can be trusted). I brought the ski out for a test ride 2 weeks ago. It's fine forever, will run for a few minutes with partial throttle, but if you high rev the engine, it acts as if the power was killed. Took it home and tested the rectifier it was pushing 16v to the battery at 5500rpm. Replaced the rectifier and tested at 5500 and 14.6ish was max voltage to the battery. I was steered to the rectifier from somebody on another forum. Not a bad call but I took another trip to the lake this weekend. Same exact scenario, I can't get more than 5-10seconds of throttle response before the motor stalls or goes to near stall if I let off the throttle quick enough. My compression may be a little low but I'm checking with HF gauges so not exactly accurate but both read 110 on it. My 01 GTI reads 100 on it and it runs perfect so I think my gauge is just inaccurate. Any ideas?
