You really need to talk to someone that knows tuning a 951 if you are going to remove the stock airbox. The carbs are lean from the get go and the loss of vacuum signal from an aftermarket air cleaner makes it even worse.
From Group K...
"Flame Arrestors – While the installation of aftermarket flame arrestors has been a very popular modification for many recreational pwc’s, we do not use or recommend them on our Swift Kit or Y2K Sleeper Kit. The technical reasoning for this choice is related entirely to the stock carbs used on the 951 engines. The carbs used on all 951s are the first generation of a carburetor that is designed as much for emissions friendliness as it is for performance. Among the most notable design features that make this difference, is the significantly increased distance between the butterfly and the “booster venturi” style fuel atomizer (aka “bombsight” atomizer). We cannot claim to know all the effects of this design departure, however we know a lot about one particular effect called “fuel delivery signal”.
In short, signal is the amount of vacuum within the inlet tract that helps to draw fuel from the metering circuits in the carburetor. The air restriction of the stock flame arrestor serves greatly to keep that vacuum very high. This high vacuum actually helps the quickness of throttle response at all engine speeds. When a free breathing flame arrestor is installed, this vacuum (aka signal) is reduced. The reduced signal means a slightly leaner fuel mixture through the entire range. This is normally not a dangerous issue for most pwc engines. However the emissions-conscious stock 951 carbs have an exceptionally weak signal at ¾ throttle opening. This means that a more open arrestor will cause the 70 – 80% throttle range become “a lot” leaner than the rest of the range. There is no jetting that can solve this problem (we tried). The “only” effective solution is to leave the stock flame arrestor (with the bolt on air horns) intact. Despite the restrictive appearance of the stock arrestor, it can easily pass enough air volume for excellent performance up to the 7140 rev limiter. The stock arrestor has received an undeserved reputation as “choking” the 951 into a bad rich condition. In truth, the rich condition is a correctable jetting issue, not an air access issue."
