Hi everyone,
1997 GTX 787 carb. SeaDoo with 210hrs
SBT 1.5mm oversized top end rebuild kit already installed last summer (150 psi PTO/148 psi MAG at cold). It came with a 6 holes aftermarket cyl. gasket. The engine run very badly from 0 to 70% throttle position. Engine does a lot of vibration, have no torque and didn't burn correctly his 91oct fuel (plugs are very wet of fuel and both piston have black carbon buil-up). Today, i mesured the squish and i have 1.8-1.9mm (tolerance: 1.2mm to 1.6mm).
1- Do you think a 3 holes (0.3mm) OEM cyl. gasket will be enough to reduce my squish into tolerances?
2- I was tinking to deck lower surface of the cylinders for a good sealing surface and also to reduce a little bit the squish.
Is it a good idea?
3- Sometime, the 2 little oil lines from the oil pump to the rotary valve cover have some bubbles in it.
Is it normal?
What I have noticed:
- Run bad 0-70% throttle position (lot of vibration, no torque, bogging, run rich, etc.)
- Run very rich at 0-70% except at 70-100% throttle position, seadoo run very nice (nice brown color)
- Idle good in and out water
- Start very well except when you leave motor off more than 20min. after riding and you try to start engine at home
- Good top speed
- Medium/good acceleration if you hit all the way down throttle
- Bad acceleration when you gradually accelerate
What i did:
- New AGM battery
- Add a extra engine ground wire
- New rectifier
- New rave valve including rave body (OEM setting)
- Cleaning Water regulator valve (OEM setting)
- Run with/without seat to diagnostic a exhaust leak (doesn't help)
- Try to pull choke when running (doesn't help)
- Carb. rebuilt with OEM needle and seat (28psi in both carb.)
- ALL fuel line changed with automobile 1/4" fuel injection hose
- Factory carb. setting
- Carb. are synchronised
- Factory flame arestor with factory air box
- New fuel selector valve and new fuel filter with o-ring
- Fresh premium 91 octane fuel
- Cleaned pick-up fuel screen
- New fuel/oil check valve and fuel pressure relief valve
- Fuel tank hold 5 PSI during 10 min.
- Trigger: 250.3 Ohms
- 2 brand new spark plug caps #1: 4.74 KOhms, #2: 4.54 KOhms
- 2 brand new spark plug wires: 12.58 KOhms
- Between all 3 yellow wires stator: 0.7 Ohms
- At 5500rpm, battery charged at 14.2V
- Spark plug BR8EIX SOLID 0.022" gap
- SBT rotary valve rebuilt (0.012" gap) and properly timed.
- Solas impeller SD-SC-XO with Solas intake grate GTX-IG-B
- Engine run with XPS full synthetic 2 stroke oil
- oil pump properly timed
- oil pump bleeded 3 time this summer and new oil filter
- 2 new 1/8" oil lines from oil pump to rotary valve cover
- All fuses are OK and all grounds in CDI box are OK
- Etc.
Thank you!
Francis
Is it a good idea?
Is it normal?
- Good top speed
What i did:
- New AGM battery
- New rectifier
- Etc.
Thank you!
Francis
