spx water in cylinders
mikeymuy
i last used my ski july 4th try to run it today found out i had water in cylinders removed plugs and water out now it starts up fine anything else i should do? could it be rusted after a week?
Take to the Lake and ride for a couple of hours.
Get some WD40 and spray in the cylinders if you are not going to ride for a couple of days.
i did compression test both cylinders came out to 150 each what should it be at new? also how does water get in the cylinders? iam a rookie sorry
If it runs good and compression is 150, I would ride it. If it is going to be a few days before you ride again I would fog the cylinders just to be on the safe side of RUST. :cheers:
P.S. 150 is great compression
