Ill be coming into my first full season with this boat(2003 Utopia 205 Merc 240, SN#OE413629) soon. I have a few questions. I did service the drive(change the oils), I fogged the engine, changed the 2 fuel filters and I have new spark plugs to replace the ones that are in there, after I run my first tank of fuel through.
1. Oil. The previous owner was using West Marine Premium 2-stroke oil so I used that for the remainder of the season last year. I was thinking about switching to the recommended Mercury/Quicksilver premium oil. Is that a good idea?? I know when switching oils there should be a clean out, what is involved in doing that?
2. Battery. Towards the end of the season I had to jump the battery to get the boat started. Between that and not knowing the age/condition of the battery, I was going to start this season with a new battery. I will still have this one tested and if it is not "dead", keep it as a backup. What battery should I get? I assune a group 24 dual purpose but is there a certain brand that is better? I know these boats are sensitive to voltage so I want to get this right for piece of mind. The dimensions of my battery tray are:10-1/2x6-3/4, but I can modify or replace it if needed. Also, I may add a second battery with a 1,2, both switch. If I do that, should I get the same battery?
Is there anything else that I should do when starting up this spring?
Thanks!
Thanks!
