If i let go of the throttle it would fall down, basically leaving you to have to hold it constantly. is there a way to make it stiffer so it will stay where you put it? some kinda of adjustment ? The other one is fine..
yes... there are set screws that set the tension on the throttle handles. you need to read and view the shop service manual to see which one you need to tighten up... they are located in the throttle control assembly.
