Hi all,I've been trying to help a friend to get his sportster Le/Le Di running better.
He bought it last year and it would only get up to around 28 mph,so he had a new impeller put in.No change then the starter went out-- end of boating season.He dropped it off Saturday with a new starter and new relay and asked if I would work on it and see what I could figure out about the performance issue.I replaced both and got it back to starting.Same issue of poor performance.So I figured best to start with a compression test
Rotax 947 compression 150/150.
I noticed on the muffler there is a whats called a reg-pression?That has a threaded female spot on it with nothing going to it.Wit the motor running it has a vacuum to it.I can't find anything that would have gone to it or anything online that shows What the hole is for.
Any help would be greatly appreciated.
