dothadoo
I have a 2003 sportster 4tec 155hp. I have an issue with blowing fuses. All three of my switches to the right of the steering wheel do not work. Right now the one that constantly blows the fuses is the switch on the far right. Not 100% sure what it is supposed to be for as it is not labeled. However, I used a circuit tester and ran it from the fuse box to the battery with each switch in the on position one at a time to figure out what switches go to what. When I flipped the far left one on, which I thought was the lights, the tester light came on when plugged into the "radio" fuse connector. That being a two position switch, I was thinking this was supposed to be for the lights. BTW, the radio does not work either. The 3A fuse for the lights blows immediately when I flip the far outside switch to the on position. Somehow it seems that the outside right switch is hooked up to that light fuse, which doesn't sounds right to me.
I am not an electrical expert and would really appreciate some help with this problem. It sounds like there might be some grounding issue, but I do not know the first place to start to look.
