trinity123
Hi guys,
Have an 06 Sportster 215hp. When you initially give it full throttle it goes no where, just revs to nearly 8000rpm... you have to gradually put the power down to get up on the plain... once on the plain you can give it full throttle and it will do 60mph no problems. But the cavitation is really bad off the line.
Wear ring and prop has a gap around it. If I put a lead light up the grate, I see a big gap between the prop and wear ring... (about 1mm gap).. also too.. the boat takes on water when you go for a 2 hour ride or so. About 3-4 litres would come out the drain plugs I think.
Whats the best plan of attack to fix this?
Thanks in advance.
Thanks in advance.
