95sportster
Was out cruising the lake a full throttle and all of a sudden the boat just died. After troubleshooting, it was the 5A fuse. I replaced it and it burns out immediately. After further investigation I found out that my 2 engine ground cables had broken loose, probably from a combination of being 17 years old and me jumping waves. A test light confirmed that one side of the fuse slot is getting power from the battery and the other side of the fuse slot is grounded which leads me to believe the diode is shorted out.
I just wanted to ask if the bad engine ground could have caused this or if there is another issue that I should be chasing before replacing/repairing the MPEM.
This is a 1995 Sportster.
